$25.20
3ds max compatibility | 3ds Max 2011 and above |
Number of profiles: | 169 |
File Formats | 3ds Max/DXF |
Instructions
- Download and instal the plugin Sweep Profile
- In the 3ds max menu “Customize”>> “Customize User Interface”>> Category “Kstudio” (or “Track” for older versions ) choose the plugin and drag it to the Panel of the Instruments.
