Products in category "Plugins"
Showing 1–12 of 13 results
3.24.00
$60.00
3DS Max Project Manager from KStudio makes keeping track of your projects much easier.
With just a few clicks, you can instantly access, preview and utilize any 3D Assets in 3ds Max. With Project Manager, laborious and repetitive tasks that often take days to complete will now require a small fraction of ...
Spline Flow, a plugin for 3ds Max, simplifies the creation of complex parametric objects based on the splines that smoothly flow from one to the other.
Users can effortlessly generate interconnected splines following a defined path, controlling their distribution and curvature.
Beyond static design, the plugin allows animate ...
$14.00
Smart Extrude is a new 3D Max Modifier that ensures the predictable extrusion of multi-spline shapes, depending to their placement across diverse planes or orientations at varying angles.
Moreover, Smart Extrude adds ...
-25%
$55.88
Unleash Your Creativity with Our Exclusive Plugin Bundle – Now at 25% Off!
🔗 Explore Individual Plugins:
Spline Flow: Simplifies the creation of complex parametric objects based on the splines that smoothly flow from one to the other.
Smart Extrude: 3D Max Modifier that ensures the predictable extrusion of ...
$18.00$60.00
Fusion is a new 3ds Max plugin with a simple interface for the parametric modeling of repetitive geometries of varying complexity.
With Fusion, you can effortlessly create and modify such objects as stucco mouldings, fences, bridges, etc. Almost any geometry can be distributed along a path and/or fused together to create an intricate ...
$8.00
Curlipse is ...
$14.00$32.00
Manage assets for 3ds Max Scenes in Batch mode
Manage assets for 3ds Max Material Libraries in Batch mode
Search/Relink/Collect/Archive multiple 3d files with assets in Batch ...
Materials Manager is a powerful plugin for 3ds Max that offers a wide range of features to help you organize and manage Materials and Textures, and create complex PBR materials effortlessly.
With its intuitive interface and drag-and-drop functionality, Materials Manager simplifies most ...
$22.00
This plug-in helps organize and use 3d models in 3ds Max.
Manage Assets for 3d Models
Preview thumbnails for 3D files.
Keep links to favorite folders and files.
Searching files by tags and file-names.
$19.50$27.00
Asset Tracking Manager for 3ds Max.
Find, collect and relink asset files.
Archive 3ds Max scenes
Support to all modern renderers.
Support to XRefs.
Support to any type of resources (images, HDR, Proxy, IES, shaders&etc.)
Select objects or materials by link.
Rendering thumbnails for 3d models, materials, and IES in batch mode
Manage asset paths for multiple 3d files (3ds max and material libraries) in batch mode
Search/Relink/Collect/Archive multiple 3d files with assets in batch mode
Rename asset paths by mask for multiple 3d files in batch mode
Custom studio for rendering ...
