At first restart computer and try again. If this wont help, follow the next steps: Looks like Windows Management Instrumentation service on your computer doesn’t work correctly. I would like to outline some common solutions that often rectify issues with WMI. 1. Restart WMI Service: – Sometimes, simply restarting the WMI service can resolve the […]
FAQ: Frequently Asked Questions
The Spline Flow’s algorithm can transform curves with different numbers of vertexes. However, for predictable results, it is recommended to follow these rules: 1) The number of vertexes should match if both curves are open or closed. 2) If one curve is closed and the other is open, the open curve should have one more […]
The easiest way is to download and install the free Lite version of the plugin. But also, before transferring the Spline Flow model, it is possible to convert Spline Flow to a spline or use the “Explode” feature and transfer the model as splines. Please note that currently, Explode does not support animation.
No, you can use the Lite version for rendering
Yes, you can open and render models created using the PRO version. If the model has two or one shapes, you can even edit such a model. However, be careful – the object’s animation will be deleted when editing.
With Project Manager you can setup a custom studio for rendering thumbnails with reference model ( like a human figure near a tree )
