Рейтинг@Mail.ru
Sweep Profile error in Max 2009 | Forum
Please consider registering
guest
Log In
Login form protected by Login LockDown.
Lost password?
Advanced Search:
— Forum Scope —
— Match —
— Forum Options —
Wildcard usage:
*  matches any number of characters    %  matches exactly one character
Minimum search word length is 4 characters - maximum search word length is 84 characters
Topic RSS
September 9, 2010
12:05
muneer
Guest
hi,
thanks alot i followed your instructions and download the latest .net from the link http://www.microsoft.com/netframework
and my track script run time error problem solved thank you very much again
May 18, 2010
13:17
Amrit
Guest
I have got error in Max 2009 “run time error: dotNet runtime exception: value of ‘100′ is not valid for ‘Value’. ‘Value’ should be between ‘Minimum’ and ‘Maximum’ Parameter name : Value” how to omit this
Thakns
May 18, 2010
13:48
Alex
Admin
Forum Posts: 83
August 11, 2009
Offline
Check with this version Sweep Profile v0.68
Please replace the older version with this or reinstall all pack
May 18, 2010
14:46
Amrit
Guest
Thanks for your hlep. but problem is same. it does not slove.
any idea.
Thanks
Yell
May 18, 2010
17:05
Alex
Admin
Forum Posts: 83
August 11, 2009
Offline
Please post screenshot with all 3dsmax window
Your version of 3ds Max and Windows (also is 32bit or 64bit ?)
Also please install (if now not have) service pack and latest hotfix for 3ds Max from this page
If possible please attach max file with this error
September 4, 2010
12:10
Chamath
Guest
Hi Alex,
I have the same problem on max 2009 64 bit. I have installed the latest hotfix and the latest track scripts you have provided. Everything goes well when I use the Sweep tool but the moment I use the shortcut ket to get thesweep tool menu I get the same error run time error: dotNet runtime exception: value of ‘100′
September 4, 2010
13:26
Alex
Admin
Forum Posts: 83
August 11, 2009
Offline
I am testing a "Sweep Profile" but I can not get this error.
I made some changes, I hope this helps.
Please test this version – download
Download and replace SweepProfile.mse in the folder "scripts\TrackScripts"
September 7, 2010
10:22
muneer
Guest
hello sir,
i am using 3d max 2009 my window is 32 bit i am facing the same problem i follow all the instructions and install latest hotfix inspite that  this error occured can you please help me i mailed you the error files and jpeg
September 7, 2010
12:52
Alex
Admin
Forum Posts: 83
August 11, 2009
Offline
You used the version of "Sweep Profile" from the link above?
Also please download this programm by link
http://www.tmgdevelopment.co.uk/versioncheck.zip
Unpack his and run VersionCheck.exe
Send to me information from window .
September 8, 2010
12:03
Светлана
Guest
Александр, замена SweepProfile не помогла, программа Versioncheck показала вот что:
http://files.mail.ru/8V89X1
Forum Timezone: UTC 2
Most Users Ever Online: 33
Currently Online:
11 Guest(s)
Currently Browsing this Page:
1 Guest(s)
Top Posters:
Member Stats:
Guest Posters: 22
Members: 1
Moderators: 0
Admins: 1
Forum Stats:
Groups: 6
Forums: 17
Topics: 48
Newest Members: Track, Alex
Moderators:
Administrators: Alex (83)
